Belly mower
Bill Jolley
12-21-2000 12:04:13
Does any one know what the five inch hole in the deck in frout of the blade pully on a belly mower is for?
Bill
Phlogiston
12-21-2000 19:12:36
 Re: Belly mower in reply to Bill Jolley, 12-21-2000 12:04:13
Bill, the blades are the "flail" type, meaning there is a bearing of sorts that the bolts go through in securing the blades. It was made like that so when you hit something you don't do damage to the mower or shafts. If you are toying with your mowing deck, I suggest a good amount of penetrating oil and a wire brush. In addition, the nuts are castilated and are secured with a cotter pin. When reinstalling sharpened blades, make sure the blades still have the flail motion. Do not over tighten. The cotter pins will do thier job.
Phlogiston.
Phlogiston
12-21-2000 12:23:57
The hole is to gain access to the bolts which secure the blades.
Bill Jolley
12-21-2000 13:42:58
 Re: Re: Belly mower in reply to Phlogiston, 12-21-2000 12:23:57
thanks For the information Phlogiston. Is there suppose to be a cover over this hole to creat an up draft when mowing?
Bill
Garnet
12-21-2000 16:26:54
 Re: Re: Re: Belly mower in reply to Bill Jolley, 12-21-2000 13:42:58
Don't think so Bill. The mowing is done on the first inch or so at the end of the blades. Any lift must be created there to be effective.(I think)
Bill jolley
12-21-2000 16:30:21
 Re: Re: Re: Re: Belly mower in reply to Garnet, 12-21-2000 16:26:54
Thanks for the info.,Grant
Bill
