Order Farmall Cub Parts Online
1950 Cub won't run!
Bill Jolley
12-22-2000 11:37:55
Hi list and Red, After starting my tractor and it running for a half minute and then dieing I puled the plugs and they were dry and covered in black dry smout.
Bill
Bus Driver
12-22-2000 17:25:59
 Re: 1950 Cub won't run! in reply to Bill Jolley, 12-22-2000 11:37:55
Bill, tell us please, you have bought the manuals, haven't you? An operators manual, a parts catalog and a service manual. To me, the parts catalog would be the most valuable of the three. The drawings in the parts catalog show how stuff goes together. The operators manual has some specifications, while the service manual has other specs. When you get aggravated with the tractor, go read the books for a while. The book learning and the hands-on experience will reinforce each other. Good luck and Merry Christmas.
The Red
12-22-2000 12:50:13
Bill you mentioned that it wouldn't continue to run when you pulled out the choke. My guess is that the float setting is off and not allowing enough fuel to flow. With the carburetor bowl removed, push up the float so the needle is closed. The distance from the bottom of the float to the edge of the upper carberutor body should be approximately 1 1/8 inches. The IT manual (they built tractors didnt' they?) states 1 13/32 inches.
dick - Red, you lost me.
12-22-2000 13:09:30
 Re: Re: 1950 Cub won't run! in reply to The Red, 12-22-2000 12:50:13
Why would the plugs be getting fouled if the engine is starved for fuel? Seems like an indicator of too much fuel to me. An improperly set float in the carb. sounds like the most likely culprit in either case. So maybe it's the right answer for the wrong reason???
Anyway, I'm confused, which isn't unusual.
The Red
12-22-2000 13:48:06
 Re: Re: Re: 1950 Cub won't run! in reply to dick - Red, you lost me., 12-22-2000 13:09:30
He mentioned sooty plugs but they were dry. If it was getting way too much fuel and konking, I would think they would be wet.
dick
12-22-2000 14:01:43
 Re: Re: Re: Re: 1950 Cub won't run! in reply to The Red, 12-22-2000 13:48:06
Would depend on how quickly he pulled them, wouldn't it? Anyway, if he cleans them and they get fouled again, we'll know more. It'll be interesting to see what the problem turns out to be on this on.
The Red
12-22-2000 14:14:47
 Re: Re: Re: Re: Re: 1950 Cub won't run! in reply to dick, 12-22-2000 14:01:43
Yep I wish Bill well. He has battled this one for awhile. I have mis-diagnosed before so it will be interesting once we got this pup, er cub, running well to see what the real culprit(s) was/were.
Jon
12-22-2000 14:09:23
Couldn't the timing be off some and cause those plugs to foul?
Bill Jolley
12-22-2000 16:36:17
 Re: Re: Re: Re: Re: Re: 1950 Cub won't run! in reply to Jon, 12-22-2000 14:09:23
Well fellow tractor nuts, I would have given up in this long ago except for yalls advice and encouragement. Yall are the Best! I promise not to give up and i'll let you know the outcome.
Bill
Jon
12-22-2000 13:23:22
Well do like Red said and check your float setting, probly the problem either way you look at it.
Bob R
12-22-2000 14:10:52
 Re: Re: Re: Re: 1950 Cub won't run! in reply to Jon, 12-22-2000 13:23:22
Was the carb. adjusted ? Is the fuel fresh ?
Sounds like its either rich or running out of fuel . Could be dirty gas tank , or clogged gas line I dont remember all the details of this tractor . Been a lot done to it . Is a steady supply of gas getting to the carb .
I had the float fulcrum pin drop on my tractor .
Would like to know if gas is pouring out the carb. or not .
Bill Jolley
12-22-2000 16:42:30
 Re: Re: Re: Re: Re: 1950 Cub won't run! in reply to Bob R, 12-22-2000 14:10:52
Bob, No gas is not running out of the carb.
Bill
Bill jolley
12-22-2000 16:45:45
 Re: Re: Re: Re: Re: Re: 1950 Cub won't run! in reply to Bill Jolley, 12-22-2000 16:42:30
Hey guys, my Dad thinks it might be the govener. It dosn't seem to be moving during the short time the engin runs.
Bill
lee
12-22-2000 18:27:47
 Re: Re: Re: Re: Re: Re: Re: 1950 Cub won't run! in reply to Bill jolley, 12-22-2000 16:45:45
Bill: forget the governor. check your fuel delivery at the carb. Remove the fuel line at the carb and run fuel into a can to check the flow. If you've got good flow, take that carb apart and check the float needle and seat are not sticking and float height properly adjusted, not hanging up on the hinge pin, no dents or pin holes in the float the float should float well in a can of fuel.
