Carb. float measurment and preasure releaf valve
Bill jolley
12-23-2000 09:42:49
Looking for the measurement from the bottom of float to top of carb. body. Also where is the preasher releafe valve located?
Bill
Phil Auten (TX)
12-23-2000 11:01:49
 Re: Carb. float measurment and preasure releaf valve in reply to Bill jolley, 12-23-2000 09:42:49
Bill,
My I&T manual says 1-13/32" from bottom of float to top of float bowl plus gasket. 1-3/8 is only 1/32" off, so you probably have it just a tad high, but probably in the functional range.
Pressure relief valve for what? The Touch Control? If that's what you mean, it appears to be under the bottom plate of the unit, near the center. Sounds like you really will need a manual for that. Suggest you wait 'til Binder is back up again.
Phil
Phil
