Float adjustment
Bill Jolley
12-23-2000 15:53:38
He The Red, You said to set the carb. float 1 1/8 inches from bottom of float to carb. topbody. With the float toutching the top of carb body it steel measures 1 3/8. it will not go up to 1 1/8. Shuarley you don't want the float toutching the top of the carb. bole.
Bill
The Red
12-23-2000 16:58:05
 Re: Float adjustment in reply to Bill Jolley, 12-23-2000 15:53:38
Bill all I can suggest at this point is to make sure the float is closing the needle just before the top of the float hits the upper carburetor body. It sounds like that is not the correct float.
RAW i IA
12-23-2000 19:32:26
 Re: Re: Float adjustment in reply to The Red, 12-23-2000 16:58:05
Red: If I remember right you said 1-1/8", then said the book called for 1-13/32", which I believe would be about 1-3/8", Right? If that is the case, his is about right.
The Red
12-24-2000 04:51:21
 Re: Re: Re: Float adjustment in reply to RAW i IA, 12-23-2000 19:32:26
You are correct RAW. I got in a hurry on the math conversion.
Bill Jolley
12-23-2000 18:38:53
That sounds right Red. I want to think you for all of you're great help. We wish you a marry Xmas and an even better New Year.
The Jolleys
