560D-- 282 motor injector holder leaks???
Alvin
12-28-2000 17:44:36
I just started a motor that wasn't run for a couple years, and the holder for the injector nozzle is leaking..Question is --does it come out easy--do I need a special puller for it--or what is the easy fix?? Would the gaskets be avaible from NAPA? Any help appreciated. Thanks Alvin
Redfan
12-29-2000 02:32:03
 Re: 560D-- 282 motor injector holder leaks??? in reply to Alvin, 12-28-2000 17:44:36
Just a couple of points Alvin. You said the tractor hasn't run for a long time, so I'd be putting the motor to work for a while and make it's tongue hang out. This just might make the injector take up. If you have to remove the injector, remove the bolts and spin the motor, you'll find the compression should pop it out. Regards, Redfan.
T_Bone
12-28-2000 20:15:03
Hi Alvin, From the parts CD I don't see any special tools required. Theres two gaskets that need replacing, upper & lower. I would get them from IH. I use Buckeye Tractor for parts. Quick and reasonable.
T_Bone
