Preasher relief valve
Bill Jolley
01-01-2001 09:05:26
Can any one send me a picture of where the preasher relief valve is on a Cub Farmall?
Bill
george
01-01-2001 10:53:50
 Re: Preasher relief valve in reply to Bill Jolley, 01-01-2001 09:05:26
Can you be a little more specific? The only pressure releif valve I can think of would be an internal component of the hydraulic control unit.
If this is the one you are speaking of, you need to remove the control unit, remove the bottom plate, and the releife valve is right there...it is a slotted screw with a hole in the center and a nut around the perimeter.
What are you working on fixing?
Bill Jolley
01-02-2001 08:51:37
 Re: Re: Preasher relief valve in reply to george, 01-01-2001 10:53:50
What is the control unit? Where is it? The tractor is making a good deal of nosies and it seems to be comming from the hydraulices. It stops when you operate them.
Bill
