FARMALL POWER STEERING UNITS
a bane
01-04-2001 20:50:57
1 have a Farmall 350 and need to know something about the power steering unit I should buy to put on this tractor. Will a 400 series unit fit on this tractor or do I have to have a 300 series unit.
Al
01-07-2001 18:49:55
 Re: FARMALL POWER STEERING UNITS in reply to a bane, 01-04-2001 20:50:57
If you are going to put a factory Belehen power steering unit on your 300, you also need to replace the Hydra-Touch Regulator Valve Part# 360621R92 with a Combined Regulator and Flow Control Valve part# 364841R93. I believe this part is the same on 300s through 450s.
Les Repair
01-05-2001 16:46:19
If you are referring to the factory installed Behlen unit, 350 and 450 are the same.
ellard ray adams
03-04-2003 05:47:23
 Re: Re: FARMALL POWER STEERING UNITS in reply to Les Repair, 01-05-2001 16:46:19
I.H. 1456 :drained hydralic system, replaced filter,adjusted shift linkage, refilled hyd. sys. now the steering sys. is real stiff and hard to move
farmall-wife
01-05-2001 16:45:42
THE 350 AND 450 FARMALLS WERE FACTORY POWERSTEERING I HAVE A 300 AND PUT A USED CHER-LIN ON THAT COME OFF A 400
