Farmall regular magneto
Bill PA.
01-11-2001 05:39:21
I need a magneto and drive plate for a Farmall regular can anybody please help me out it would be greatly appreciated thanks Bill Pa.
Brad
01-11-2001 20:37:24
 Re: Farmall regular magneto in reply to Bill PA., 01-11-2001 05:39:21
Howdy Bill: If I'm understanding your questions correctly, the Mag drive plate you mentioned is actually called the mag coupling block spacer, Part #12741 D. Gordan @ Rice equipment will have one.(814) 226-9200. As far as finding a mag, it depends on how original you want. If you just want to get it going, the international f-4 will bolt up and work great. If you want to keep it with how it was produced then it becomes a little more work to find one. pre-1931 used the E4-a mag with a manual impulse coupler (splitdorf) Early 1931 and latter used the E4-a but with an automatic impulse coupler. Most any salvage yard should have an f-a and rebuild parts are available from Rice. Hope this helps. Brad
