Live hydraulic pump
Bart
01-12-2001 15:26:20
Can anyone tell me if a live hyd. pump from a Super M will fit an M.? If not, can it be adapted? Thanks for any replies. Hey Red, How are you?
Red Button
01-12-2001 19:53:40
 Re: Live hydraulic pump in reply to Bart, 01-12-2001 15:26:20
There better be 2 holes about 1/2 hole off. after the supers came with live Hyd. IH made some off set studs so one could mount the pump on the M don't know if can get them now.
Les Repair
01-12-2001 17:06:01
It will fit except one of the mountiong holes is about 1/2 hole off. I've seen where guys ran a bolt in the hole, cut it off and then drilled and tapped the new hole. It works. You can also change the timing cover with a Super or 400 450 one.
Jim
01-13-2001 10:43:02
 Re: Re: Live hydraulic pump in reply to Les Repair, 01-12-2001 17:06:01
The late M's ( 1950 and up?)have the Super M front cover on them.
Look at your cover and if it has a casting number that ends in a R number then you have the late cover.
