Roosa master injection pump
560D
01-16-2001 07:11:58
we've got one of these on our 560D.we want to turn it up a little.-has anyone ever done this-can it be done at home,and if so,-how? Thanks a bunch!
Les Repair
01-16-2001 17:09:49
 Re: Roosa master injection pump in reply to 560D, 01-16-2001 07:11:58
I think Wardner may be wrong. You can't see the leaf spring screw through the timing cover hole. Call me 641 847 2731. Its easier to explain on the phone.
Wardner
01-16-2001 19:15:24
 Re: Re: Roosa master injection pump in reply to Les Repair, 01-16-2001 17:09:49
I defer to you Les. The procedure I described works on Stanadyne pumps. Both types of pumps look similar from the outside so I figured they were similar on the inside.
Les Repair
01-18-2001 16:57:24
 Re: Re: Re: Roosa master injection pump in reply to Wardner, 01-16-2001 19:15:24
Wardner,you have been playing with pumps on Ford and Chevy pickups I'll bet. Thay have a different cover.
Wardner
01-18-2001 17:15:52
 Re: Re: Re: Re: Roosa master injection pump in reply to Les Repair, 01-18-2001 16:57:24
Yep Les, I have a 6.9 F350 with Hypermax turbo, altered intake and exhaust, cab controled ignition timing, and propane injection. It goes pretty good, probably better than a late Powerstroke.
Les Repair
01-18-2001 16:55:22
Wardner
01-16-2001 16:31:09
All right I will take a whack at this seeing as nobody else has. Even though I have a 660 I have not done this. You need to remove a rectangular plate (5/8 x 1 1/4) on the side of the pump. It is held on by two machine screws. Rotate the motor slowly until you see a deep hole. At the bottom of the hole will be an allen-head screw. Probably 5/32 socket. It will require maybe 25-40 ft-lbs to turn. Turn clockwise to increase fuel. Start by turning only 60 degrees. Put the small plate back on and start the tractor. You should see a significant increase in power at full throttle. If it is not enough power turn the screw another 60 degrees. I would not exceed 180 degrees total. This adjustment is usually done when a turbocharger is added. Your exhaust will blacken appreciably without one. Another easy way to increase power on a diesel is to inject propane vapor in the intake. You could probably get 25-30 hp.
You should also check your throttle linkage to make sure the pump is actually at "wide open throttle". I realize that diesels do not have throttles but I think you know what I mean.
Red Button
01-16-2001 19:00:56
 Re: Re: Roosa master injection pump in reply to Wardner, 01-16-2001 16:31:09
Can not get at leaf spring through timing cover on side of pump need to take off top cover of pump then trun engine over and down through the top of the in side there is a hole to get at the screw.
