A Steering repair
anton rothbauer
01-25-1999 01:12:43
Turn and a half with steering wheel before wheels move. Have not figured out how to start. Should I remove the whole thing from engine front or just the base. That is after I get the main axle off. Sounds like a major job! The steering box shaft appears to have dropped down too?
Anton
Curt Cooke
01-25-1999 06:13:54
 Re: A Steering repair in reply to anton rothbauer, 01-25-1999 01:12:43
Anton, don't take the unit off the tractor, remove the bottom half of the steering box by first removing the steering arm which you can now do because you have the axle out of your way. Now remove the bottom half and get it out of your way. Next remove three 5/16" bolts that hold the verticle steering shaft in place and remove the shaft. Play in steering results from up/down play in this shaft usually caused by bad upper bearing or missing snap ring on top of it; bearing at the end of the steering wheel shaft, evident by the shaft moving in and out of the case when turning the steering wheel back and forth; play at the point where the steering arm attaches to the verticle steering shaft; worn keyway in the gear on the verticle steer shaft. Have fun, you can win.
What is this
01-25-1999 04:42:15
What tractor is this
