M Compression
Blu
01-19-2001 14:36:33
I got a compression Tester for Christmas and not sure what to do. Should I remove all the plugs while performing the test,or just remove the plug from the cylinder that is being tested. I did a test with leaving them in exept one and got 90psi. I always heard you should at least have 100psi. The tractor runs good. Any help would be great.
Phil Auten (TX)
01-19-2001 17:36:44
 Re: M Compression in reply to Blu, 01-19-2001 14:36:33
Blu,
Once you get the numbers for all the cylinders, they should be within 5% of each other (or so).
90PSI sounds ok for an M, they didn't have very high compression to begin with. The "standard" gasoline compression ratio for an M is 5.65:1.
A Kerosene or tractor fuel M would've had 4.5:1 or so.
Phil
Roger
01-19-2001 15:23:29
Also, make sure that the throttle is wide open and choke is not on.
Phlogiston
01-19-2001 15:19:13
Yes, conduct the compression tests with all the spark plugs out. Let the tractor turn over several times until the needle stops advancing. Didn't you get any instructions with the unit?
Blu
01-19-2001 17:26:07
 Re: Re: M Compression in reply to Phlogiston, 01-19-2001 15:19:13
No,the instructions where not very helpfull. Thanks for your help!
