Power steering on Farmall 140?
67Steve
01-20-2001 15:19:02
Is it possible to add power steering to a Farmall 140? If so, has anyone ever done it? Thanks.
Potosi
01-21-2001 12:04:19
 Re: Power steering on Farmall 140? in reply to 67Steve, 01-20-2001 15:19:02
Yes it is possible,I put it on my 140. It uses the tractor hyds.I use a six foot woods finish mower on the back, and powersteering helps alot.I can tell you the info you need.lynn@bluebuzz.com
Potosi
01-21-2001 12:03:52
Potosi
01-21-2001 12:03:29
Potosi
01-21-2001 12:02:53
Haas
01-20-2001 17:19:14
I suppose anything is possible, however, the 140 steers pretty easy and it's going to cost quite a bit. The units that go on the H and M work on the steering wheel shaft and I bet one of those could be made to work on the 140. I guess you could add a pump for it, or maybe even figure out a way to use the hydraulics on the 140 since it has a live pump. It's gonna look real ugly though with that power unit and all the hoses showing.
