Can't get a Distributor Cap for an International Tractor????
Bill
01-20-2001 15:51:41
Have a resurected International 3414 (B414 painted yellow ). Is equipted with a Lucas Distributor. The thing lays dead in my shop for lack of a Distributor Cap & Rotor. The local International dealers laugh at the idea that I'll find a new or even good used set for the machine. I'm told they were primarily imported to Canada from England. There has to be a source out there to get a cap & rotor. Anybody have any ideas I can chase?
Bus Driver
01-21-2001 10:48:39
 Re: Can't get a Distributor Cap for an International Tractor???? in reply to Bill, 01-20-2001 15:51:41
Bill, I know nothing about your tractor. You mentioned a Lucas distributor. A long shot, but maybe the same parts from Ferguson TE-20 might fit. They used Lucas. An MG might have used the same thing. Also, maybe a distributor from a USA Farmall might fit your machine. Let us know when and how you solved the problem. Might help lots of other folks.
T_Bone
01-20-2001 16:58:02
Hi Bill, Try part# 811735 cap or 3047513R1, #3069778R1 for the rotor or 3047514R1
Cap 3047513R1 and rotor 3047514R1 go together as a set.
The reason for two parts numbers is there different depending on what application the engine was in.
T_Bone
T_Bone....And Try Here For Parts!
01-20-2001 17:01:42
 Re: Re: Can't get a Distributor Cap for an International Tractor???? in reply to T_Bone, 01-20-2001 16:58:02
Also try getting parts from Buckeye Tractor. Barts prices are very good and his service is excellant.
mike
01-20-2001 18:04:04
 Re: Re: Re: Can't get a Distributor Cap for an International Tractor???? in reply to T_Bone....And Try Here For Parts!, 01-20-2001 17:01:42
I did a dealer search for a new cub crankshaft, and buckeye came up as having one.. I called, and it was used but reground (without bearings) and they wanted $1,400 for it.. I had to ask for the price 3 times just to make sure my ears were working right... Not to reasonable as far as I am concerned... heck you can get a rebuilt crank from CT for $350 (with bearings), and a new crank for $400 (no bearings)
mike
01-20-2001 18:02:56
mike
01-20-2001 18:02:29
