Order Farmall Cub Parts Online
12v conversion on farmall cub
ange
01-22-2001 16:39:10
I am thinking of converting my cub to 12v is this wise thing to do and how do I convert it if I can. thanks
John
01-23-2001 22:13:59
 Re: 12v conversion on farmall cub in reply to ange, 01-22-2001 16:39:10
Having done one 6 to 12 volt conversion, I found myself asking why afterward. The reason I was aking why is becaused I realized there is no reason to convert only excuses. The 6 volt system was only abandoned by the auto industry because the 12 volt system cost less to install per unit. In short the bean counters made the call to go to 12 volts.
Bob M
01-22-2001 16:58:21
Whether or not to convert depends. If you want best reliability and lowest maintenance cost (i.e. you're gonna use the tractor for work), a 12 volt alternator conversion is the only way to go. On the other hand, a well-maintained 6 volt system will start a well-maintained tractor under almost any condition. And a stock 6 volt system is necessary for a historically "correct" restoration if that's how the tractor was originally equipped. Finally, there's just something cool when a 6 volt tractor engine makes 3 or 4 halting half revolutions, then lights off.
Bottom line is the choice is yours! If you decide to do an alternator conversion, punch the link for step-by-step instructions.
