560 Overheating
Brent
01-24-2001 11:38:20
I have a 560 gas that has all of a sudden decided to overheat after one or two minutes of running and "erupt" anti-freeze out of the radiator fill hole. Would this be a stuck thermostat? If so, is it located above the water pump under the top radiator hose? Any help would be appreciated. Thanks!
George
01-24-2001 12:14:04
 Re: 560 Overheating in reply to Brent, 01-24-2001 11:38:20
Brent, Sounds like classic symptoms of blown head gasket.Usually when they bubble or blow that fast it's a head gasket, hope it is something simple but that is where i'd look, keep us posted, Geo.
Brent
01-24-2001 12:26:58
 Re: Re: 560 Overheating in reply to George , 01-24-2001 12:14:04
How do I diagnose a blown head gasket? Sorry if I'm stupid but I'm an agronomist, not a mechanic.
Thanks!
george
01-24-2001 12:43:47
 Re: Re: Re: 560 Overheating in reply to Brent, 01-24-2001 12:26:58
I would start it,and let it idle slow and look for bubbles in the radiator filler cap. It shouldn't have any, also check for water/ antifreze in the engine oil, also sometimes they will miss on the cyl. that is leaking. also you shouldn't put any engine under a load when it is cold, that is a quick way to blow a gaskett. good luck Geo.
Brent
01-24-2001 13:00:43
 Re: Re: Re: Re: 560 Overheating in reply to george , 01-24-2001 12:43:47
Thanks for the info. Here in Iowa I keep it plugged in in the winter and then warm it up for 20 minutes to heat the hydro fluid before I use it. It doesn't seem to smoke "white" like a car I had did when the head gasket blew. I will check the oil and watch for bubbles.
Is it a tough fix? I am pretty handy but have never pulled a head before.
George
01-24-2001 13:17:13
 Re: Re: Re: Re: Re: 560 Overheating in reply to Brent, 01-24-2001 13:00:43
Brent, I would think a decient shade tree mechanic could do it. if you don't have a repair manual get one, don't skimp. I would say its easy but I can fix most anything. Think about having the hd. resurfaced. these new gaskets don't have asbostos in them and don't have a good rep for not leaking use the high torque specks +10 # lube the threads and follow the torque secquance in at least 3 steps. I'm sure you can get all the help you need with these guys that read the board. Good luck
