Which hardener w/2150 paint?
Brian CNY
01-25-2001 18:50:33
I have decided to paint my 140 with the caseIH 2150 paint. After reading posts here I have decided to use hardener with it, question is how do you determine which one? Please don't suggest another type of paint as this will never be a show tractor (it has seen a tough life from a previos owner) Thanks for your help
Jon
01-25-2001 19:08:16
 Re: Which hardener w/2150 paint? in reply to Brian CNY, 01-25-2001 18:50:33
I use Evercoat D.O.I. Wet Look Acrylic Enamel Hardener. I think as long as you get a decent enamel hardener you will be alrite.
the tractor vet
01-25-2001 19:21:34
 Re: Re: Which hardener w/2150 paint? in reply to Jon, 01-25-2001 19:08:16
We use DuPONT 77S hardner with 2150 IH paint over top of IH primer ,If i could ever figure out how to use this scanner i would post pictures of the 3588 that is comming out of the paint booth.
Doug D....Other questions
01-26-2001 11:18:41
 Re: Re: Re: Which hardener w/2150 paint? in reply to the tractor vet, 01-25-2001 19:21:34
What reducer do you use? At what ratio do you use the reducer and hardener with paint. Do you use reducer or hardener with IH Primer?
Thanks. Doug.
Jon
01-26-2001 13:38:26
 Re: Re: Re: Re: Which hardener w/2150 paint? in reply to Doug D....Other questions, 01-26-2001 11:18:41
I use 2oz hardener, 2oz CaseIH reducer/thinner to 1qt of CaseIH 2150 red. I don't use any hardener with the primer, just use around 3-4oz reducer to 1qt primer and it will shoot out just fine at 40-60psi.
Bill D
01-26-2001 04:44:55
I`ve used the fiberglass and Dupont both don`t see any difference in any thing but price
