Super M (dyno question)
BigJ
01-26-2001 11:55:12
What kind of horsepower would a (supposedly stock)good running Super M be capable of on a dyno?
the tractor vet
01-26-2001 19:01:00
 Re: Super M (dyno question) in reply to BigJ, 01-26-2001 11:55:12
We have one Super M that is turnig out 64 HP at pto speed and one S/MTA that is turn out 87 hp at pto. My persnal S/MTA turns 58.5 hp at pto.Just dependes on the pistons and head and manifold and timing that you have.
Jerry
01-26-2001 14:58:20
In the early sixties when I worked part time at an IHC dealership I remember we had one Super M that cranked out 53 horse on a fresh overhaul with fire crater pistons. Stock without fire crater pistons would be somewhat less I would imagine
BigJ
01-26-2001 19:05:23
 Re: Re: Super M (dyno question) in reply to Jerry, 01-26-2001 14:58:20
Thats not bad at all.I hope mine is close to that because I want to pull it some,as well as use it some for odd jobs.I have a 70 John Deere that I pull also in the stock classes and was hopeing this super M will do as good,if not better.Thanks Jack(TN).
The Red
01-26-2001 12:08:01
Don't know about the dyno. From guy Fay's IH Data Book, 42HP on the drawbar and 47.5 HP on the belt pulley or PTO.
Charlie
01-26-2001 12:50:19
 Re: Re: Super M (dyno question) in reply to The Red, 01-26-2001 12:08:01
The M&W dyno book rates the Super M at 46.3 hp at 537 PTO RPMs loaded. The High Idle speed or no load speed with wide open throttle should be 590 RPMs.
good luck
