Farmall M front wheels and tires
Al
01-27-2001 16:27:36
I'm looking for a Farmall M or Super M. Have located a nice M, it is a 1950 model but it has the non-adjustable front wheels and rims like the older H's and M's had. I did not check the casting numbers to see if they appeared original with the tractor. If I decide to buy it, I would like to change it to the adjustable rims that most of the later M's, Super M's, 400 and 450's had. Would I just be able to swap the wheels themselves or would I need a whole pedistal?
thanks,
Al
RB
01-27-2001 17:50:05
 Re: Farmall M front wheels and tires in reply to Al, 01-27-2001 16:27:36
The wheel and the hubs will need to be changed,but the hubs will fit the shafts.
Norm
01-27-2001 16:32:59
Thinking you just need to change wheels. I have only seen 1 M with this style of hub.
farmall 43
01-27-2001 16:37:24
 Re: Re: Farmall M front wheels and tires in reply to Norm, 01-27-2001 16:32:59
The 400 is basicly a SMTA. So if you can find the parts they will slide on just fine. Good-luck
