steel rim paint
in sticks
02-08-2006 18:07:03
is there any need to put a finish coat of paint on inside of tire rim where tube touchs rim? already have two coats of primer and sanded smooth.
Farmered
02-11-2006 04:55:29
 Re: steel rim paint in reply to in sticks, 02-08-2006 18:07:03
I use NAPA high temperature aluminum. It is intended for use on manifolds and exhaust systems. You will find that it dries smoother and looks more like the original finish than regular aluminum paint. It lasts longer before rust shows through too. Ed
Ga Jack
02-10-2006 13:56:48
Check out a Benj.Moore product called Ironclad.
It's used to paint exposed metal beams. I have used this on two tractors, inside the front and rear wheel rims. It does require complete drying before mounting the tube and tire. Prep work, as with any type of painting, is what really makes it work/look the best. Good luck, have fun, jackie
souNdguy
02-09-2006 12:04:54
I agree with the other poster.. most primers aren't sealed. I like to use an epoxy paint ont he inside of my rims.. it's darn tough and fluid / chemical resistant.. so if your tube leaks.. it will help protect the rim if you use CACL.
Soundguy
B-maniac
02-08-2006 19:06:21
Depends on the type of primer used. Some of the old laquer types and non-catylized primers will actually absorb moisture letting it through to the metal and then rusting. They need top-coated. Use an epoxy and it dont.
