Air pressure
greg gramps
04-17-2008 14:11:55
I have an Oliver standard 77 for antique pulling not modified at all other than oversized pistons (one size over)putting out a whopping 40 H.P. I have Titan 14.9 x 28 tires with a 23 degree angle, they are new but not cut and have pulled with them for a couple years. i pull in the 4500lb class and sometimes in the 5500lb class. What air pressure should I run in these tires, I usually run about 8 lbs. and my tires curl pretty good about 3/4 the way down the track and I personally think they curl to much. Any help would be great. Just want to be a little more competetive. Thanks
AO
04-17-2008 14:39:17
 Re: Air pressure in reply to greg gramps, 04-17-2008 14:11:55
Increase until you are pleased. Tracks differ so pressure will to
