CHANGING VALVES IN A
Wade
06-27-2002 18:15:57
I want to change valves in my A to G size valves.But I need smaller stems. Any sugestions.Thanks Wade
bigmotors
06-29-2002 07:55:13
 Re: CHANGING VALVES IN A in reply to Wade, 06-27-2002 18:15:57
Bore out your guides. A 70 to 730 valve or use valves our of a CAT. I think it might be a model 4 or 6. It's been awhile. Take your "A" valve to a CAT place and try to find the right one to make sure. A old 22-36 IH valve work also. Some big Fairbanks and Waukesha motors will work too.
Good Luck!
SEAMO
06-27-2002 20:26:37
Wade, Do you have a styled A or unstyled A?Too big intake valve on the ramp head will defeat the purpose unless you try and flycut around the valve area of head. Earl
Mike in Mo
06-27-2002 19:20:55
If my memory serves me correctly, I had 730 gas valves put in my A. The stem diameter was correct, but they had to be shortened and a new groove for the locks/retainer turned in it. Mike
Wade
06-28-2002 11:42:13
 Re: Re: CHANGING VALVES IN A in reply to Mike in Mo, 06-27-2002 19:20:55
I have A styled A 1947 model.Any other atrnatives.Thanks Wade
