ChadS
05-01-2008 07:20:48
Re: 350 engine into a Super H in reply to Jake Winn, 05-01-2008 07:08:18
Yeah, keep the Super H rockford clutch then. If your SH is 6 volt, I think there is a 6 volt positve ground kit,, 12 volt negative if its been converted for IH distributors are the horizonal type, most delco were verticaly mounted, and has an angled tooth gear instead of the straight fine tooth the IH dizzy has. I think, even the cap is different on the Delco. Ive seen Super H's beep the 3 mph at 10% with 15.5s, 3.5 mph with 14.9s in low gear. If the sled is pretty light and easy to pull for the lite tractors,, then might run 2nd gear in 3500, but its gonna be asking for all its got, which, could be a good thing if it does and dont stall, or,, if its not enough and quits 6 inches to early,,,,, But low gear, if the sled is heavy and the tractors get a good hook up,,, with th 13.6's,, if they are tall,,, then you might have a pretty good shot if it hooks up and dont over power the tires by aggresive driving. Can ya run front suit case weights? ChadS
