H Super H transmission gear teeth numbers
MM ZAck
05-06-2008 16:41:28
Does anybody know the tooth count for the gears in Super H transmissions? I'm looking for the sliding gear counts, the ring & pinion and the bull gears. Also, where are the differences between the Super H and H transmissions? Is it in the sliding gears, ring & pinion or bull gears? I believe they both use the same 18-55 constant mesh. I'm curious because I'm calculating the over all reductions for each gear on both tractors.
Thanks,
Zack
bradd
05-07-2008 05:30:20
 Re: H Super H transmission gear teeth numbers in reply to MM ZAck, 05-06-2008 16:41:28
Zack, the gear differences is in the sliding/driving gear combos. i believe that first and reverse is the same and 2,3,4th is faster in super h. to get exact tooth count go to caseih.com and go to parts search and pull up parts book. Hope this helps. Another option to speed things up is to put a w4 ring and pinion in.
brad
MM ZAck
05-07-2008 07:38:59
 Re: H Super H transmission gear teeth numbers in reply to bradd, 05-07-2008 05:30:20
Awesome. That's exactly what I was looking for! Thanks!
