Flatback
followers of we
05-12-2008 11:29:21
Does anyone know of a website that has aluminum flatbacks for a John Deere B that you can mount the seat and battery box onto??
jd b puller
05-13-2008 18:13:49
 Re: Flatback in reply to followers of weber, 05-12-2008 11:29:21
You can use the seat from the 41-46 models.
E-mail is open.
algar
05-12-2008 18:21:33
K&K antique tractor Shelbyville ,Ind. has the alums.
730-LP
05-12-2008 14:54:18
Don't know of anyone making one for an A.But if you will remove the powertrol from the outside and the piston and rock shaft from the inside you will not be much heavier than a alum and will still have the pto to use on a dyno or pull in farm stock classes where a pto is required.[When you remove the rock shaft get 2 freeze out plugs and drive in the holes]
Followers of Weber
05-12-2008 15:12:51
 Re: Flatback in reply to 730-LP, 05-12-2008 14:54:18
Well i have a flatback for it that i bought on ebay, with the PTO hole. But the only thing is that i want to keep my seat and battery box. I was at a pull and seen some guys with these aluminum ones where the seat and battery box would bolt right on to them. They told me that they got them on the internet, but i have yet to find them.
JDTH
05-13-2008 05:28:33
 Re: Flatback in reply to Followers of Weber, 05-12-2008 15:12:51
K & K has the aluminum covers for both the A & G, haven't seen them for the B's. Have made a couple out of flat aluminum for the pan seat tractors.
