Wanted: 9 Bolt Hubs For John Deere A
ksstang
05-16-2008 08:34:12
Hello everyone. I am in the process of building a pretty serious puller with my 1949 John Deere A. I am in search of a pair of 9 Bolt Hubs to be used with Pressed Steel Wheels. If anyone could direct me on a good place to start looking it would be greatly appriciated.
Thanks!
Kyle
ksstang
05-21-2008 04:01:14
 Re: Wanted: 9 Bolt Hubs For John Deere A in reply to utupuller, 05-16-2008 08:34:12
mjjk said: (quoted from post at 18:45:56 05/17/08) I have a set of adaptors that go from 6 bolt to 9 bolt if you are interested
How much are you looking to get out of the adapters?
ksstang
05-19-2008 04:01:19
 Re: Wanted: 9 Bolt Hubs For John Deere A in reply to strokin, 05-16-2008 08:34:12
hubs said: (quoted from post at 22:22:51 05/18/08) i have a couple sets of JD pressed steel hubs so you don't have to worry about findng the right rim dish for the weld on style. give me a call if your intersted in a set. located in michigan..248-789-2645
Could you email me what a price on a set of those would be? My email is klmstang@hotmail.com
Thanks,
Kyle
hubs
05-18-2008 19:22:51
 Re: Wanted: 9 Bolt Hubs For John Deere A in reply to ksstang, 05-16-2008 08:34:12
ksstang
05-17-2008 22:16:41
Thanks for the relies everyone. I honestly can't decide whether I want to weld the 9 bolt hubs to the axle then cut the axle off flush, or.... whether to try and find original ones, or make adapters to use the ones that are on the tractor now with the cast center wheels.
When I'm said and done... this 49A is going to be a pretty serious puller wearing some 18.4 x 38's on pressed steel.
So.... maybe some advice one what you all think would be best.
Thanks!
Kyle
mjjk
05-18-2008 03:59:49
 Re: Wanted: 9 Bolt Hubs For John Deere A in reply to ksstang, 05-17-2008 22:16:41
Kyle, I made a set of adaptors about 13 years ago and have had no problems with them. When I made them it was lighter to leave the old 6 bolt hub on and put the adaptor on than put on the john deere 9 bolt hub on, also alot cheaper.I have a extra set of adaptors out in the shed if you are interested, I would like $140.00 for the set. Let me know if I can help.
Larry Baker
05-17-2008 17:39:26
dont know exactly what you want here
do you want some bolt on's or some what? either way i have some of each.We make plates for a's uns A's and G's that bolt onto the original centers also not weld on's
mjjk
05-17-2008 15:45:56
Mike n Mo
05-17-2008 04:42:12
Are you wanting the origional John Deere hubs, or weld on hubs? Makes a big difference on where to look. For weld on hubs, try Murphy's Motor Service as stated below (www.murphysmotorservice.com). For the John Deere hubs they should be widely available at salvage yards, at least for 15 spline axles. Try googling for tractor salvage yards or www.atis.net which is a salvage yard listing to find one in your area. Good hunting!! Mike
ksstang
05-16-2008 18:45:11
 Re: Wanted: 9 Bolt Hubs For John Deere A in reply to ChadS, 05-16-2008 08:34:12
jd b puller said: (quoted from post at 19:18:34 05/16/08) ksstang, not sure how far along you are, but I've got a 6-2 Powerblock punched out to 6.5" with pistons if you're interested.
Would you mind emailing me at klmstang@hotmail.com with alittle more info on this?
Thanks!
Kyle
jd b puller
05-16-2008 16:18:34
Hoss in Me
05-16-2008 14:34:41
Murphys motor service.comormurphys Motor Service,311b Hwy00,Hallsville Mo 65255 or 573-696-3655 Hoss
ksstang
05-16-2008 12:47:27
Hoss in Me said: (quoted from post at 12:31:44 05/16/08) Murphys. Hoss
Murphy's??? Is that a member here, or a place of business?
Thanks,
Kyle
Hoss in Me
05-16-2008 09:31:44
Murphys. Hoss
