1 wire napa alternator
newhpuller
05-21-2008 17:36:49
I hooked up my new 1 wire napa alternator and my baterry died, Did i hook it wrong or does my tractor not have enough rpms at an idle.
guido
05-23-2008 16:07:53
 Re: 1 wire napa alternator in reply to newhpuller, 05-21-2008 17:36:49
HELLO newhpuller.
The ratio in R.P.M.'s between the engine and the alternator is 1 5/8,One revolution of the engine , 1 and 5/8 revolutions of the alternator. With the engine speed at least 500 R.P.M.'s. This would make the alternator run around 750rpm's and should start charging.Put a volt meter at your battery terminals if you get 14V at 70 Degrees F. the alternator is charging.
Guido.
buickanddeere
05-22-2008 15:42:22
The one wire alternator is not the simple solution it appears to be.
Get the cheaper three wire alternator and wire it in properly. It will excite at low rpms and won't flatten the battery.
770
05-23-2008 07:00:14
 Re: 1 wire napa alternator in reply to buickanddeere, 05-22-2008 15:42:22
I"ll second that!
Welding man
05-22-2008 14:22:09
NAPA 1 wire has to turn approx 850 RPMs to start charging, if it drops below that it will drop out. Depending on what size pulley you have on it, you may have to rev it up pretty good to get it to start charging, but it should not run the battery down when not running. I have them on three different tractors and they work fine.
Cliff S
05-21-2008 18:29:11
Did you rev the engine high enough to entergize the alternator?
