Sugar in the ol gas tank
ChadS
05-25-2008 13:21:07
Some jacka$$ sugared my gas tank on my 69 ford Maverick!! Ive heard horror stories on what it does, but I dont think it got in the engine too much,,,, ran for about a minute and died. Took the filter off, sugar, inside the brand new carb, sugar. Whats the best way to clean it all out??? I dont know who, nor am I blaming, I just want to fix it and get a locking gas cap. Funny,, gas being 4 bucks,, I figured somebody would have stolen the gas!!! Damn kids these days. No respect!! LMAO!!
Pat-CT
05-26-2008 15:03:43
 Re: Sugar in the ol gas tank in reply to ChadS, 05-25-2008 13:21:07
ive had good luck with seafoam it cleans the carbon out of an engine like no onesbuisness otherwise water it is
mEl
05-26-2008 03:10:56
Hey chad, Just an idea, would a heavy dose of water fed down the carb while it was running dissolve the crap, set the throttle up a ways and feed water into the intake a while. We used to do that to breakup heavy carbon accumulation and you havn't a lot to lose, mEl
buickanddeere
05-25-2008 19:10:03
Might be able to steam clean the carbon out of the engine if you inject a heavy mist of windshield washer fluid down the carb for an extended length of time.
Weldernils
05-25-2008 17:49:06
The only thing that will dissolve sugar is water. That's why it's such a f*&^er. Had a customer car get it. No carb clean, brake clean etc would do it. Only water. Hot water is best. Sure you can figure it out from there.
BTW. Next time I send you an email asking for help, do me a favor and answer it.
ChadS
05-25-2008 18:00:09
 Re: Sugar in the ol gas tank in reply to Weldernils, 05-25-2008 17:49:06
Id be happy to! Send me an email and Ill do what I can. Sometimes, I dont get emails cause of my spam filter,,, but ChadS3@hotmail.com is the address, Ill be looking for it. Chad
ChadS
05-25-2008 18:06:54
 Re: Sugar in the ol gas tank in reply to ChadS, 05-25-2008 18:00:09
Weldernils, I just found 5 emails that I didnt know were there in my junk file,,, All from different fellas, so let me know whats up or post it here and will get ya pointed in the right direction. Sorry bout that! What are ya working with? Chad
ChadS
05-25-2008 18:45:15
 Re: Sugar in the ol gas tank in reply to ChadS, 05-25-2008 18:06:54
Well I just finished responding to what I found, hope you were one of em! Chad
ricky c
05-25-2008 16:46:49
this type of coward needs to be tied to a tree stripped down and pour liqued sugar on them and let the ants clean it off. MY 2 CENTS
Allan In NE
05-25-2008 15:51:09
Chad,
If it will restart and run, you're okay.
If it won't start, figure on tearing 'er down 'cause all the valves will be stuck open and the rings will be stuck solid.
Goop looks just like black carbon; the combustion heat turns that sugar into a gel (about like running molasses thru ‘er) and it will look like Mom’s apple pie after it’s boiled over in the oven. That black burnt crap.
You'll have to hot tank the whole she-bang.
Allan
ChadS
05-25-2008 17:40:52
 Re: Sugar in the ol gas tank in reply to Allan In NE, 05-25-2008 15:51:09
Well, they say it completly disolves in gas, and its not detectable... Well, when the open air hit the open carb, it like reforms into a gooo, almost like a thin jelly when it dries out. It did not have much gas in the tank,, maybe 3 gallons at most,,, so a 5 lb bag would be real bad.... Fuel pump is ruined, Im not sure about the carburator yet,,, I cleaned it out as best I could, but its smoking bad. Im thinking of trying to mix some marvel oil in a small tank and hook it up to see if it helps clean it out. I suppose for no more gas it had it got enough in it to do damage. What gets me is,, I never drive the car,,, when I dont work on the tractors, I tinker with this ol car. I had the tank off it a year ago and cleaned it out, so I know it was clean before, and never had problems out of it till today. I wish they would have just stolen the gas!!!! But so far, it does start, it sounds ok, but it smokes oil burning now. Poor old Ford,,,,, its exactly the 50,000th Maverick off the assembly line when the first started production in 1969. If the engine is ruined, I may just pass it along to the next fella for a project. I dont want to,, but, it may be best for the car to keep it from being destroyed by vandals.
B-maniac
05-25-2008 19:23:46
 Re: Sugar in the ol gas tank in reply to ChadS, 05-25-2008 17:40:52
Just curious , Chad , but what year is on the title of the Maverick? I know the mfg. date is prob ably '69 but what is the model year stated on the title?
ChadS
05-26-2008 06:02:21
 Re: Sugar in the ol gas tank in reply to B-maniac, 05-25-2008 19:23:46
1970. From what I understand, the cars that were built in early 69, were all sold as 70 models. Only one way to spot a 69, is the key switch is not on the steering column, its located down on the right, beside the steering column, bolted to the package tray. They did the same sales tactic for the Maverick as they did the 64.5 Mustang, so the 1969 models, were considered 1969.5 models, even though ALL titles say 1970. The build date is July 9, 1969 for this one, it was sold in Florida, where it spent 5 years of its life with the original owner, then he moved to Indiana. My uncle bought it 76, and it sat in a barn till I got it in 1993. He did not drive it, the suspension looked like it was tweeked, so he was leary,,, turned out the eccentric on the lower control arm had slipped, and made it look like it something was wrong. I dropped in 5.0 out of 88 mustang GT, C4 cruiseomatic transmission. Ive neen slowly fixing it up, I have yet to put any body filler in it, and it does not need any, its still solid as a rock. The battery tray is rough, but thats the worst spot on the entire car. In all the years Ive had it, Ive yet to put 50 miles on it, even after I dropped in the engine. But, from what I did drive it, it had a nice ride, and is still pretty tight still. 74K miles on it. Well, looks like I need to build a hot water injection system to get it cleaned out, I may just pull it apart and do it right, but it sounds good, and the smoke is going away. Had it running this morning, good oil pressure, so maybe it might live, but only time will tell. Thanks guys and gals for letting me vent, Now back to tractor pulling!
AO
05-25-2008 19:16:08
Back in the Viet Nam era they called it FOO GAS, or a cheap version of napalm, thus the gel like substance. You're probably right in that hot water is the way to go. Good Luck!
George MacPherson
05-25-2008 13:48:39
Does anyone know where I can buy a locking gas cap for an Oliver 77?
ChadS
05-25-2008 17:45:43
 Re: Sugar in the ol gas tank in reply to George MacPherson, 05-25-2008 13:48:39
I had one for an 88!!!! the cap where the lock is,, has a sliding cover that is not real easy to slide to put the key into, but yeah, there are retro fits outhere that will fit the stock tank. We picked this 88 up a while back and it had it on there,, dont know if I still got it or not,,, it was chrome!!
