Electronic ignition help
770
07-05-2002 11:37:48
Put pertronix elect ign. on my 77 ollie. I know its wired right, and I know the coil and resistor are right. I have the same set-up on several olivers. What makes this one different is this tractor has a generator on it. Someone told me my gen might be "spiking???" Anyone out there have similar problems??? any ideas??? thanks in advance..... .....770.
DON LC
07-09-2002 10:36:40
 Re: electronic ignition help in reply to 770, 07-05-2002 11:37:48
I can't help you don't know about them...Since you have it on other tractors you must think it is worth the change over.....I have a FARMALL M that is hard to start,i am changing it over to 12v....what do you think about putting electronic ignition on it??? When you get time I would be interested in your opinion....
TimC
07-08-2002 09:19:35
Are you trying to say it will not start after you installed it? Does it run rough, miss, what are the symptoms?
770
07-08-2002 17:14:31
 Re: Re: electronic ignition help in reply to TimC, 07-08-2002 09:19:35
It will run for about an hour then the module pops. I have the gap set at .030 on the ignition. Any ideas??? Thanks.
