Pullin a 60 J.D.
Rman
07-05-2002 20:17:13
I have a 60 J.D. that I am building up. How much can i stroke it and bore it? And where can i get this done at? Do they make roller rockers for one? Where all should i shave on the block and head? And is there anyone who makes headers for deere's? Thanks for the help!!
JD PULLER
07-07-2002 12:53:44
 Re: pullin a 60 J.D. in reply to Rman, 07-05-2002 20:17:13
go the max!!
9.250 stroke and look around for good power block.
Port the head and use 720 valves. Buy a 70 carb also. Then look out!!
Rman to JD Puller
07-08-2002 20:29:07
 Re: Re: pullin a 60 J.D. in reply to JD PULLER, 07-07-2002 12:53:44
JD Puller-- Where could we get this work done at and where can we get the parts to do it? how much would we have to modify to get the 9.250 stroke in it?? I would like to send all of it to one guy and get it done. Also do you know where to get a set of aluminum 16.9/38 9 bolt rims? Thanks for all the help!!
Deere A
07-07-2002 07:32:07
You can prbally get around 8 in. of stroke without too much trouble, and a powerblock with G pistons (6.125) will be about the max bore available. the block would be about 1200, and the pistons are around 450 a set. The stroke would be around 900$ were I'm from
hope this helps
Deere A
07-07-2002 07:31:59
hope this helps
Rman
07-08-2002 20:19:05
 Re: Re: pullin a 60 J.D. in reply to Deere A, 07-07-2002 07:31:59
How much do you have to modify with the 8 inch stroke compaired to the 9.250 inch stroke? Do i get a G powerblock or a 60 powerblock?? Thanks for all the help!
G-MAN
07-09-2002 13:31:59
 Re: Re: Re: pullin a 60 J.D. in reply to Rman, 07-08-2002 20:19:05
You'll probably have to go with a 60 powerblock, as a G block won't fit without massive modifications to the maincase and frame. Ever seen the difference in frame width between a 60 and a 70?
G Taylor
07-05-2002 20:47:57
If this is your 1st pulling tractor the 60 is very capable in the 6500 & 8000lb classes bone stock/cheap. The creaper 1st gear,road worn 15.5x38 Firestone traction field and road tires with proper weight balance/max legal drawbar height will pull plenty. Traction 1st then HP. A few extra ponies are available cheap , 1st from a dry aircleaner conversion, then a straight stack and tuning the mixture/timing on a dyno.
