Carb tricks
Flyin Farmall
07-10-2002 21:01:08
What do you guys do to your carbs???I know about using 806 kit.do you just polish the inside or is there more to it??just looking for some cheap tricks!thanx.
LESTER DAVIS
03-09-2006 05:47:01
 Re: carb tricks in reply to Flyin Farmall, 07-10-2002 21:01:08
I GOT A1939 FARMALL M I GOT A450 MOTER WITH SUPPER KIT IN THIS ALSO GOT LP HEAD THIS HEAD ALSO HAS BIG VALVS I WANT A GOOD CARB FOR THIS. WHAT SHOULD I GET OR DO FOR THIS? THANKS LD
Pete1468
07-15-2002 14:33:40
The bigger venture and drilling out the full load jet to get enough fuel to it. Make sure the gasket lines up good. I've even seen some with larger throttle plates in them.
