Extrude honing
lw
05-14-2001 18:26:45
I am curious , is any one trying this porting method on heads, and , or manifolds since it is the most productive porting aid.
G Taylor excellent value
05-15-2001 22:10:07
 Re: extrude honing in reply to lw, 05-14-2001 18:26:45
The extrude hone allows porting of the head & manifold as a unit for improved flow. It removes metal from restrictive points without oversizing the port causing a loss of low end torque.
Jake
05-15-2001 03:56:25
I have wondered the same thing. My guess is that it would be better to use on long, twisty stock intake manifolds than it would be for porting the head. On the heads, you want to 'shape' the ports some so I don't think it would be as good. Just my thoughts. I would be curious to hear from somebody who has used it.
glenn
05-15-2001 04:14:29
 Re: Re: extrude honing in reply to Jake, 05-15-2001 03:56:25
I uesd it on a manifold, works great. Expensive thou, The inside was smooth as glass when they were done. It's best to do any hand work or grinding in it first, then it will be blended in very well after the honing
John
05-22-2001 18:27:56
 Re: Re: Re: extrude honing in reply to glenn, 05-15-2001 04:14:29
Who does it and how much does it cost?
Glenn
05-22-2001 18:32:40
 Re: Re: Re: Re: extrude honing in reply to John , 05-22-2001 18:27:56
E-mail me, I'll give you a place
