Farmall A puller.
Farmer Joe
07-15-2002 10:37:16
Has anyone ever swapped in a Super C engine into an A? What do I have to change to do this? Are there any specific heads that produce more power? My father has an M and there are different heads he could use on that, but I don't see much for the 113 and 123 engines. Thanks.
cd
07-15-2002 15:55:00
 Re: Farmall A puller. in reply to Farmer Joe, 07-15-2002 10:37:16
why not get an engine from a 240, mine is cranking 34hp and will still bolt up as far as i know
Farmer Joe
07-15-2002 16:12:11
 Re: Re: Farmall A puller. in reply to cd, 07-15-2002 15:55:00
What size is the 240's engine? What have you done to it? <-You don't have to give away any secrets!
cd
07-16-2002 05:21:22
 Re: Re: Re: Farmall A puller. in reply to Farmer Joe, 07-15-2002 16:12:11
well the 240 engine is 123 but IH would "tune" the engines with some better parts and stuff to get more HP from virtually the same engine, I dont know even if this engine has been opened ever, I bought it and it runs good and it has put out the best HP on regular gas 87 i think at 34, all I did was turn the rpms up to 3000 but it was already around 2500 when i got it but it really cranks for what it is, oh and the muffler is gutted, I have a 240 engine but I would like to build my other 240 back up to pull or put it in a B or BN or Super C
cd
07-16-2002 05:22:26
 Re: Re: Re: Re: Farmall A puller. in reply to cd, 07-16-2002 05:21:22
oh i forgot to say that i have spun it out at 1/4-1/2 throttle at 4700 lbs (ran out of weights and tire pressure
