Farmall H pulling gear?
Bob
07-17-2002 10:34:02
I have a Farmall H with oversize pistons in it. And in a week or two I am going to be participating in my first tractor pull for fun and I can't decide if I should use first or second gear.(The sled has transferring weight) Any thoughts would be appreciated. Thanks Bob
Puller504
07-30-2002 18:44:16
 Re: farmall H pulling gear? in reply to Bob, 07-17-2002 10:34:02
Stick to first gear, Bob. Stock H's don't breathe well enough to hold second gear. We had 2 H's on Dad's farm, I got Grandpa's back before Dad died. To hold 2nd gear, you'll need a 350 Farmall intake manifold, carb, and head to take advantage of your big pistons. Good luck and great pulling.
JOhn
07-19-2002 15:46:06
I'd pull in low, unless you have about 90 hp.
John
jimmy funk
07-28-2002 20:13:24
 Re: Re: farmall H pulling gear? in reply to JOhn, 07-19-2002 15:46:06
i pulled my h it was a big transfer we were all joking around about pulling in high gears i went in first and got 3 inches i was ashamed but it was pretty funny lots of laghs jimmy funk
p.s mine was y under stock horse
KEN
07-17-2002 10:49:17
You will probably have to use first gear.If they are using a short chain that sled will pull you to the ground and limit tire spin and pull hard on your tractor.There is a long way between first and second gear when pulling a sled,it takes a lot of horse power to go up a gear.
