Cockshutt 30 for Pulling...
Bruce
07-17-2002 13:26:41
I have recently retired my 1954 Cockshutt 30 gas trractor from the field and am thinking about pulling with it locally.
Where is the best place to put money into the tractor?
Are there any easy horsepower gains to be made? Any stroker kits or other $$ modifications?
Many thanks,
Bruce
SHUTT30
07-18-2002 13:29:52
 Re: Cockshutt 30 for Pulling... in reply to Bruce, 07-17-2002 13:26:41
Nothing easy or cheap. 3-9/16 overbore, stroke it, and get a cam. goodluck
Andy
07-17-2002 16:50:02
If they are stock pulls I would work on traction first, (drawbar, wieght brackets, tires) try it and if power is a problem then go from there.
Bruce
07-18-2002 07:12:59
 Re: Re: Cockshutt 30 for Pulling... in reply to Andy , 07-17-2002 16:50:02
Andy, Most of the rules in the area don't allow for much modification, but regulation is pretty lax.
There are guys Running JD 630's straight out of the fields to guys with fully restored Cases and Massey's who definatly don't have stock engines.
A lot of the pulls in our area use a dead-weight sled, and not the weight transfer kind.
Do you know any common tips or tricks for creating power or getting it to the ground?
Andy
07-18-2002 15:31:54
 Re: Re: Re: Cockshutt 30 for Pulling... in reply to Bruce, 07-18-2002 07:12:59
Raise your draw bar or make one that is the highest that rules allow. You may want to keep it 1/2" below the limit so you can inflate/deflate your tires depending on the track.
Bruce
07-18-2002 07:33:53
The only thing I have heard mention of is the the more straight across the tire the tread is the more forward bite the tire has.
Bruce
07-18-2002 07:49:15
 Re: Re: Re: Re: Cockshutt 30 for Pulling... in reply to Bruce, 07-18-2002 07:33:53
23 Degree lug angle made by Firestone
