Farmall M pulling advice
dauber
07-21-2002 20:54:55
I had my first pull and loved it. I had my hitch set too low and spun out way easy. It was still fun and looking for some info on where to start on building the old m up to pull. I dont use it for anything else. Any help would be great.
Thanks
54SMTA
07-23-2002 18:46:24
 Re: farmall M pulling advice in reply to dauber, 07-21-2002 20:54:55
I pull a stock Super M-TA. I feel that I am pretty competitive, and I have only done some simple modifications to my tractor.
The first mod you want to attempt is shortening your drawbar and making it adjustable some way, i.e., bolt with a D shaped ring and stack washers under it. Simple, yet very effective. Run the highest and shortest drawbar you are permitted, which gives maximum downpull on the rear of your tractor when she gets to pullin :) (this transfers to traction!)
Next, build weight brackets. One in front and wheel weights are common, I have one built behind the axle and two that are under the belly in front of the axles to hang suitcase weights on. I am able to pull my tractor from 6500 to 10500 lbs. 9500 and 10500 I run with the TA back from the start, but you don't have that option :)Straight M's run best from 5500 to 8500, depending on what the motor is made of. Learning how to weight your tractor properly is the biggest key in pulling successfully. This takes lots and lots of practice as well as patience.
Third, get some good rear tires on her. I run 15.5 x 38's, and most M's do that are pulling. I've heard that a 14.9 does decent and have seen many pull with 13.6's. Firestone Field and Roads seem to be the most popular. The key is to find a tire that is about shot and really really road worn to give a sharp edge to the cleats. Mine are that way, and have had people ask me if they are cut. The tires were gotten from a 656 that did a lot of road work and I haul my share of wagons on the road as well. When pulling, you want to play with the air pressure, and finding the best pressure for the weight class and the track takes a lot of practice and a lot of patience.
Finally, make sure you tractor is in top running condition. Make sure the governer is tight, the timing is exact, new points and plugs, carb is adjusted perfectly, etc. All of these contribute to a good run down the track.
Practice, practice, practice! That's what it takesto learn. Have a ball...email if you have any questions.
M's rule!
54
dauber
07-22-2002 21:51:42
I would like to start with some simple stuff first.I heard that different carbs and manifolds would be a big improvement over stok. I just dont know what models too go and get. I have been looking at the cam and pistons that Dennys carb has but would like cheaper ideas first.
Thanks for any info
Dauber
Pete1468
07-23-2002 16:13:10
 Re: Re: farmall M pulling advice in reply to dauber, 07-22-2002 21:51:42
I would start with a different cam and some port and polish work on the head. A 450 carb is an improvement over an M carb. From then on is based on how much you want to spend.
M Advice
07-22-2002 18:38:43
I'd like the same advice. I'd like to have the best "stock" tractor that I can. I'd like to stay in DivII.
Pete1468
07-22-2002 14:04:06
How much power do you want and how much money do you want to spend? You gave some pretty big guide lines in your question.
'39 M Puller
07-24-2002 12:10:54
 Re: Re: farmall M pulling advice in reply to Pete1468, 07-22-2002 14:04:06
I have got a totaly stock 39 M farmall just
restored. We have only added an adjustable hitch,
weight brackets and whellie bars of course, a
Super M governor spring, NGK high performance
spark plugs, and a cold air intake.And we can pull
with the 450's and I should no cause thats what
our other M has in it.
