Autolite or AC plugs for G
Matt B
07-23-2002 04:14:10
I am currently running Champion D21's in my G, but I am not much of a Champion fan... I do a few local pulls with this tractor, and would like to know what AC or Autolite plugs work for other people. Engine is pretty much stock, orignial 12V + ground, standard points&condensor, etc. I'm running pump gas, nothing fancy, just want to stop replacing plugs every couple of months.
Thanks
MWB
Mike S
07-23-2002 21:07:29
 Re: Autolite or AC plugs for G in reply to Matt B, 07-23-2002 04:14:10
I run autolite plugs all my tractors,use Autolite no# 3116
M. W. Hylton Jr.
07-23-2002 12:18:39
Jesus son, I wouldn't run Champions in my lawn mower! Get either the ACs or the Autolites and forget about plug problems with your machine.
Jack
07-23-2002 08:12:50
Autolite 386 or 388's depending on how rich it runs with the 388's being the hotter.C86 is the AC number and is what I am running now in my G.Hope this helps.
Mike
07-23-2002 11:17:41
 Re: Re: Autolite or AC plugs for G in reply to Jack, 07-23-2002 08:12:50
I have good luck w/ the autolite 386. I did have 1 set go bad, pulled em they looked fine; threw a new set in and have not had any more troubles
rich
07-23-2002 19:25:35
 Re: Re: Re: Autolite or AC plugs for G in reply to Mike, 07-23-2002 11:17:41
if you want to run a hot plug NGK makes one that will replace your stock plugs the number that is on the plug is A-6 the stocking number is 1010.they are super great plug and i have never fouled one in two years.they are really great if you run high octane fuel in your tractor and have a real hot ignition system on your tractor.
J.J.
07-25-2002 07:51:52
 Re: Re: Re: Re: Autolite or AC plugs for G in reply to rich, 07-23-2002 19:25:35
Bought a set of N.G.K. A-6 for my 1950 "G".Will not fit due to the 1 inch hex. What gives? Went back to Auto Lites.
J.J.
07-25-2002 07:50:13
DP
07-23-2002 04:48:21
Will have to look to see the number, but am running AC, and haven't had a plug out of the tractor since 1991. 1938 "G"
CASEPOWER
07-23-2002 05:21:40
 Re: Re: Autolite or AC plugs for G in reply to DP, 07-23-2002 04:48:21
In my experiance I have had better luck with AC plugs not fuel fouling. DP thats only 11 years yours should be good for another 10 or so..
