1953 sm cam grind (screwed up)
bud bareenie
07-24-2002 17:21:01
rebuilt a 1953 sm (total restoration) had the cam ground to 209 x 209 duration 281ci motor !
ported head and manifold. super m top carb 806 bottom. tisco dome pistons old set dug out of a nother motor! when the tractor loades up she falls rite on her face !!! yes i tried to out engineer ih !!! bullet cams did the work !! is the cam giving to much overlap !!! tractor snaps from low idle to high ! fires with in 2-3 revolutions, timing by the book. had a ground problem, but fixed that !!!! 450 cam better!@!!
need help middle of season and i need to get to work in the shop !!! on the motor!!!pulling farm field 1st gear ! no cut tires !!! stock appaearance
Brad
07-25-2002 11:53:12
 Re: 1953 sm cam grind (screwed up) in reply to bud bareenie, 07-24-2002 17:21:01
sounds like a good question for Goldsberg. Where is your timing set at? What was the stock spec for that engine. Have you degreed the cam in motor to double check the specs? Is intake centerline as installed matched up to cam card? Stock timing gears have alot to be desired and can vary from gear to gear. Bullet has done work for guys that I know and they are very happy, but they are tubocharged diesels. Good Luck!
BUD BARENIE
07-26-2002 05:05:56
 Re: Re: 1953 sm cam grind (screwed up) in reply to Brad, 07-25-2002 11:53:12
to all the guys who have replyed!!! thank's for all the info (no i did not degree the the cam with a timing wheel!! put the cam back in straight up on the dot's and dashes!!! did have motec rebuild the carb and changed venturi from super m (#29) to an 1/8" larger !!! probably the first thing to fix !!! please understand i'm not complaining about sonny at bullet !!!! heck of a nice guy !!!! this is my first rebuild, and going thru the learning curve !!!!
check timing gear lash, set valves at the books tolearances !!!! i'll check compression and readjust valves again !!! let you all no !!! pull
on tuesday!! at south bend in just want the girl to run down the track !!! thanks again to all
Seamo
07-25-2002 09:34:49
Bud , Does your tractor miss and quit or do you think you have just lost bottom end lug.When you installed the cam was the cam timing Ok? Take compression reading at full throttle. Then adjust valves to .030 take compression reading let us know where your at.What kind of vacuum does it draw at full throttle ?You will have to use vacuum gage with damper to get correct reading. Does your cam grinder understand low rpm engines? Have you talked to him about it so he has a chance to defend himself. Earl in Illinois
BUD BARENIE
07-26-2002 05:09:22
 Re: Re: 1953 sm cam grind (screwed up) in reply to Seamo, 07-25-2002 09:34:49
earl talked to cam guy!!! cam should be just fine
have not checked vacuum the boys up here don't think it's important!!!! also this cam duration has been sold to many other bullet customers , so i sure there!!!! need to find the quirk!!!!
thanks for reply !!!
TimC
07-25-2002 08:46:59
A little help (maybe a lot) would be to add 10 thousands or more to the valve lash especially on the exhaust side. It sounds like you may be droping the vacume and the motor stops breathing and as the rpms start to fall you are not filling the chamber.
Any way, it can't hurt to try. This should decrease the duration a little.
BUD BARENIE
07-26-2002 05:11:44
 Re: Re: 1953 sm cam grind (screwed up) in reply to TimC, 07-25-2002 08:46:59
i'm running a straight pipe 3" and the exhaust is extremely loud !!!! i thing the over lap is opening the exhaust valve way to soon very good advice !!!!
Hayne D. Matthews
07-24-2002 19:26:13
I have the same cam with firecrater pistons and 450lp head and LP manifold, runs great, dyno's at 95hp. do you have a stroke in the crank?
Hayne D. Matthews
07-24-2002 19:25:53
I have the same cam with firecrater pistons and 450lp head and LP manifold, runs great, dydo's at 95hp. do you have a stroke in the crank?
frank
07-25-2002 10:42:51
 Re: Re: Re: 1953 sm cam grind (screwed up) in reply to BUD BARENIE, 07-25-2002 05:54:07
bud i'm no expert but i would try another carb that was known to be a good one.or just put the one you have now back to stock as a troubleshooting measure.we had 400 that ran fine until the carb was modified.that thing was an aggravating SOB no amount reworking could fix.that carb was replaced with one that modified identically and it worked perfect.apparently the original carb had a casting flaw in the throttle body that didnt show until it was reworked.
BUD BARENIE
07-26-2002 05:14:40
 Re: Re: Re: Re: 1953 sm cam grind (screwed up) in reply to frank , 07-25-2002 10:42:51
frank totally rebuilt carb by motec !! tractor starts great idles smooth !!! just under heavy lug is their a problem !!! sm top plate, 806 bowl big jet andemulsion tube i'm just about sure i should have stayed with the same venturi (stock)
thank's for reply
frank
07-26-2002 08:21:36
 Re: Re: Re: Re: Re: 1953 sm cam grind (screwed up) in reply to BUD BARENIE, 07-26-2002 05:14:40
bud, we have motech carbs on a couple of our farmalls.give'im a call and i'll bet he can get you pointed in the right direction. frank
bud bareenie
08-01-2002 04:40:12
 Re: Re: Re: Re: Re: Re: 1953 sm cam grind (screwed up) in reply to frank, 07-26-2002 08:21:36
just had motec redo the first carb,went to a bigger emulsion tube and bigger venturi! took the carb apart and matt completely butchered my old enturi!!! putting a different one in . at low idle to midrange the carb sweats like crazy now. never did that before!!!!
