G 7 1/2'' Long Blocks
bryan
05-18-2001 04:57:20
Has anyone purchased these new blocks from Schooler Motor Sports yet? How much grinding is required to make them fit? Thanks.
al
05-20-2001 06:37:29
 Re: G 7 1/2'' Long Blocks in reply to bryan, 05-18-2001 04:57:20
Long block would probably mean it is styled after the unsty G F485 block or you will get into a non-stock argument.1 inch longer than the powerblock or the styled G block.I'm not sure though on the size of Alan's.
I made my own and I went back [into] the case about 2 in without a spacer using the 485 block x 9.375 stroke.That's where my pistons stop there bottom travel.
As G man says you still have a time keeping up.I'd say you have a strong Div 3 and a medium to low power div 4 .But you will enjoy the power against other Deere's. 4th and sometimes 5th gear in 5500lb
Also the jury is still out on how much a G crank can stand with 400 + cubes per journal.
Gman
05-20-2001 01:00:59
Bryan to run a 7.5 you need a 1" to 2" spacer between case and block to make them functional and you know what this does for you,so ask your self a question can I stand the heat in Div. 4 & 5 then you will have your answer.Drop me an email some time. Gman
