Hand clutch slips on WD Allis
Big Orange
07-29-2002 14:31:52
Has anyone ever bolted up the transmission clutch to prevent slippage? I have a WD tractor with a WD 45 engine. I have adjusted the clutch by removing shims, but it will not last. I do not need the hand clutch for the antique tractor pulling. So if i could lock it together some way , would be great
John
07-30-2002 05:57:58
 Re: hand clutch slips on WD Allis in reply to Big Orange, 07-29-2002 14:31:52
I had a similar problem and drilled through (5/16")and bolted the "pack" when engaged together. I went through the top by removing the inspection cover. I could not go parallel to the centerline of the tractor and ended up at a little angle but has worked fine for 2 plus years now.
