JD aluminum pistons
TF
07-30-2002 19:40:58
I have aluminum pistons that are 6 1/8 inches in diameter. What running tolerance should the block be bored for this size piston? What ring gap should be run?
Thank you.
a puller
07-31-2002 07:22:56
 Re: JD aluminum pistons in reply to TF, 07-30-2002 19:40:58
An aluminum G piston should be around .012-.014 of clearance(sp). Sorry, I don't know the ring gap. the rule for cylinder clearance with aluminum pistons is .oo2 and inch of bore.
A puller
