Can you run an M w/o sleeves?
08-01-2002 12:49:29
Can you bore an M block?, How much is safe? If not can you run one without sleeves? This is a stock M.
54SMTA
08-05-2002 13:49:31
 Re: Can you run an M w/o sleeves? in reply to ????, 08-01-2002 12:49:29
Don't know w/o sleeves....
But I do know you can bore out an M block to accept sleeves for 4 1/4 inch pistons.
Doug in OR
08-01-2002 18:47:36
Absolutely maybe!
From what I've been told, you can bore the block to accept sleeves for 4 1/8 pistons, but the success you have will depend on how much corrosion you have in the water jackets.
Does this help? I've decided that I won't bore my M. You can install 4 sleeves for 4 inch pistons w/o any boring - if you want.
