FARMALL 450 in a M
Don LC
08-02-2002 20:32:00
What would have to do to put a 450 in a M ?
North Star
08-04-2002 15:36:05
 Re: FARMALL 450 in a M in reply to Don LC, 08-02-2002 20:32:00
F#ck you don't have to do nothing. Its a bolt in install. Or you can bore out the ends and put airs 4-7/16 bore and just gas it.
Burrr Hurrrrr rr
Don LC
08-03-2002 21:01:56
Don't need to worry about me pullin this tractor....My grand father was a IHC dealer....the family sold the property years ago..... on his personal property we came across an old M in great shape --no engine ....upon looking futher we found a 450 engine complete short block and head....enought parts to put the whole thing togeather....the estate now belongs to my cousin.....I was curious about the fit.....thanks for the information....
JCM
08-03-2002 12:39:45
the arm on the governor is different from a "m" also the choke control on the carb is on the inside versus the outside on a "m". if your are concerned about getting "attention" remove the raised casted "c281" on the block just above the oil filter housing below the head by a little grinding.most people are not aware of the date code castings on the block/head any way. other wise like the other posts no problem...enjoy!
Doug in OR
08-03-2002 15:07:07
 Re: Re: FARMALL 450 in a M in reply to JCM, 08-03-2002 12:39:45
And don't forget to change the oil pan. And get rid of the dipstick. Oh yeah, you can't completely cover up the place where the dipstick goes into the motor - it is large and cast in the block.
There are differences between the M and the later 400 and the 450 engine blocks. Will someone really care? Probably not - unless you start walking away with too much of the booty.
Doug in OR
08-03-2002 12:25:40
Why not just bore out the M block and put 450 pistons/sleeves in it? You'll have nearly the same horsepower, and it won't look so obvious to those who can tell the different blocks, as I can.
Dr. Evil
08-06-2002 13:02:38
 Re: Re: FARMALL 450 in a M in reply to Doug in OR, 08-03-2002 12:25:40
You can't bore an M block enough to accept 450 pistons without "Hitting Water".
farmallflogger
08-03-2002 08:34:29
Yep the good news is it's a bolt in. The bad news is it really tees off some of the competition. Good luck anyhow.
deadeye
08-03-2002 05:15:00
Unscrew the bolts and screw them back in again.
Trailer Hitch
08-03-2002 08:18:42
 Re: Re: FARMALL 450 in a M in reply to deadeye, 08-03-2002 05:15:00
Yes it will work,no problem but it will get you run out of South Carolina.
G Taylor
08-03-2002 08:25:03
 Re: Re: Re: FARMALL 450 in a M in reply to Trailer Hitch, 08-03-2002 08:18:42
Don't forget to tell everyone it's stock if asked.
