In a jam
CASEPOWER
08-06-2002 12:28:55
I have high alltitude pistons that come about 1/8 above the deck. I have been looking for a gas head and now have found out that with the gas head the pistons don't have anywere to go. It only has a bathtub like chamber and it is the same level as the deck of the head around the chamber. I thought about milling the pistons level were it won't hit the head and leave it high were it goes in the head. Just turn it into a dome piston. That is if the piston is thick enough. Any other ideas?? I need to get the head down to 120 cc to get the compression I want.
LW
08-06-2002 18:35:09
 Re: In a jam in reply to CASEPOWER, 08-06-2002 12:28:55
There is probably plenty of mat. there to make them into a dome, bring them over and i'll help you out.LW
Case Jim in Florida
08-06-2002 18:06:04
Did you look at a 5576 all-fuel head. It amy work for you.
joecool
08-06-2002 15:14:47
What is this on? a cc head is open where a dc head is either closed or semi closed chamers. Don't forget your gasket thickness, you could use 2 gaskets and no machine work is necessary.
