I need help to win a tractor pull
ryan
08-06-2002 18:50:15
i have a 1947-1950 john deere b to pull with
i was wondering if there is anyway to get more power well pulling in 1st gear reply if you can thank you
Jim M
08-09-2002 18:17:08
 Re: i need help to win a tractor pull in reply to ryan, 08-06-2002 18:50:15
I pull my Case DC and 500B against a J/D B as you have desribed. He has beat me a couple of times and won the class. With a hard track a B with slow gears will ease over the bad spots without spinning out. Weight it so the front tires are a little off the ground at the end of the pull. Stay in the classes with the lowest drawbar rule.
36ajd@msn.com
08-08-2002 17:10:26
those red things are a legend in their own mine if they think a m will beat a john deere and oliver is just a want to be john deere stay green and learn the tractor and learn to read the track and you will be a winner
bud bareenie
08-15-2002 15:22:04
 Re: Re: i need help to win a tractor pull in reply to 36ajd@msn.com, 08-08-2002 17:10:26
how do you read the track
kspuller
08-08-2002 07:54:32
Buy a M-H or an Oliver
Running Red
08-07-2002 19:31:39
Trade it in for a super M and you will win them all!!
huhhhh
08-12-2002 09:11:05
 Re: Re: i need help to win a tractor pull in reply to Running Red, 08-07-2002 19:31:39
wats wrong with u????? ????? ? who woulg trade an
m 4 a jd hahahahahaha
A Man
08-07-2002 17:20:16
ryan be sure to watch other puller before you pull and read the track that is my biggest problem make sure your tire presure is very low like 8 to 10 psi but do not go to low and beat those red things on the track they claim are tractors good luck and let me know how you do
G-MAN
08-07-2002 07:15:11
Ryan, start with a good tune-up - replace points, plugs, wires, etc. Check compression. Check the operation of the carb and adjust it and the timing for maximum power on a dyno if you have access to one. All of this will help you get the most out of your tractor and will provide a baseline to measure the effectiveness of any future modifications. Don't worry if you're not getting 50 hp out of your B - more pulls are won by proper tractor set-up and track reading/driving than are won by horsepower. All the power in the world won't do you any good if you can't get it to the ground. There's nothing funnier than watching a hopped up tractor get spanked by a stocker because the owner didn't know how to weight the tractor and read the track.
Baystatebinder
08-07-2002 04:37:43
PAINT IT RED
