Gbd moline
George
08-07-2002 05:02:24
what is best way to put pressed steel on this stile of tractor.any one make a hub that fit this style of axle thanks for any suggestions
CWR
08-08-2002 10:36:13
 Re: gbd moline in reply to George, 08-07-2002 05:02:24
I reversed the hubs so the flat side if facing out and bolted through the wheel weight holes on the wheel centers. Needed to resize two holes and dimple the wheel center in four places so there was a flat spot to make 4 more bolt holes. Depending on the wheels you have, you may have clearance problems between tire and tractor.
JK
08-08-2002 06:04:44
George,
Chuck the original hubs in a large lathe and turn them to accept a 9 bolt rim then drill and tap the bolt holes.
JK
Shawn
08-07-2002 10:20:13
Hello,
I dont know why you just can clamp on some regular M&W 9 bolt hubs and get by, but if that wont work you cna change the axles and axle housing to U axles they are 3" and can be swapped out, i have never tried it but that what i have heard
hope this Helps
Shawn
