Farmall m block
TL
08-09-2002 15:03:34
If you were considering building an m,would you use the block or go with a superblock,I would like to build a stroker and have no idea what to use,or amount of stroke.Yes I could call Lemmons ,but to those of you that build them what do you guy's use,if you don't mind someone asking thankyou for any advice
bigmotors
08-10-2002 06:15:47
 Re: farmall m block in reply to TL, 08-09-2002 15:03:34
I've been told a early M block like 1939, have more room for a crank. This I can't say is true. A "M" block you can bore out to 4.31, and a 400 - 450 block to about 4.42 bore. I found a good set up to be a 4.5 X 7.250 to 7.500 with H rods. It's not the biggest, but puts out good power, and will last. I know some people are going 5 X 8! But, will it live?
Good Luck!
farmallflogger
08-09-2002 15:39:45
About the only difference in the blocks is that the 264/281 have about an 1/8" more cyl wall thickness. If you're going big, you'll bore all of it out anyway. There's less to bore out on the standard M block and you can still make it as big as the super m or 400/450 blocks. I think the first thing I'd do is check the rules where you're planning on pulling. Some clubs don't allow non-oringinal blocks. Next try to make friends with someone who has built one of these engines before. There is a lot more involved than I ever realized. I wouldn't hesitate calling the folks at Lemmons either. Their primary business is selling pulling engines, but they've always been nice to me and have answered a few questions I had as well. Lots of luck, and let us know how it turns out!
Seamo
08-09-2002 15:26:47
If you tractor rules allow go with the 450 block.It is much stronger block.450 LP head,stroke can be whatever you want to spend. Where do you live? ( Earl In Illinois )
TL
08-09-2002 16:02:45
 Re: Re: farmall m block in reply to Seamo, 08-09-2002 15:26:47
Southeast In.
WILDMAN H
08-12-2002 05:40:28
 Re: Re: Re: farmall m block in reply to TL, 08-09-2002 16:02:45
YOU HAVE ONE THE BEST CLOSE TO YOU . LEMMONS TRACTOR IN RUSHVILLR IN. ASK FOR PAUL OR GREG.
