Farmall M Rear Weight Bracket...
Vic
08-20-2002 15:01:26
Hello all,
Do any of you M pullers know where I can get a bolt on rear weight bracket? I have a pull in a couple of weeks and I don't think I'll have time to make one.
I'd like something that will bolt on right under the seat and hang off the back.
Any ideas?
wvcrash
08-21-2002 14:24:15
 Re: Farmall M Rear Weight Bracket... in reply to Vic, 08-20-2002 15:01:26
Take a piece of angle ( 4x3 ) and make it the width of the inside of your tires minus 2 inches on each side, remove the down brace on one side of your platform hitch, slide it in and drill 2 holes in the angle, using the 2 existing holes that are already in your platform hitch ( have the 4 inch side on the angle standing up) thats the side you want to hang your weights on. you can hang about 5 or 6 100lb IH weights on each side and about 4 75lb IH weights in the middle of your platform. let me know if you need further.
Flyin Farmall
08-20-2002 18:35:04
Bolt a piece of angle iron on the end of your platform.
