Front tire size?
235
08-21-2002 18:14:45
I need smaller tires on my 620. What is the smallest size I can go to? What else can I do to gain traction on my tractor?? I cant build weight racks or add weights because I pull in the heaviest class which is 6500. And I weigh 6493 on the tractor. Thanks 235
al
08-22-2002 17:44:41
 Re: Front tire size? in reply to 235, 08-21-2002 18:14:45
Put steel 9-bolt rims on it
KEN C.
08-21-2002 20:42:57
With the roll a matic front end any smaller rims will hit.You would have to use a reverse rim and that makes for some harder steering.I think you can change the front end to a straight spindle then you could go as small as you want.As far as traction, get the draw bar to maximum height, biggest rear tires as possible.Without weights to move around it limits your choices.Just some ideas.
