M More Power,RPM's,or other Enexpensive upgrade
39 M puller
08-23-2002 14:47:29
Hey all You Farmall Pullers! I was wonderin how to
get more power or RPM's out of our M. We hav just
ordered some msd boxes.Ya think they will help.
And we are condiderin some pressed steel rims. All
coments are appreciated.Don't wan't anything toooo
expensive we pull 5600 and 6600if it helps and are
usual 1 or 2 winners. We want to pull in 2 gear.
P.S. 4 is always better than 2
jim
08-23-2002 19:10:28
 Re: M More Power,RPM's,or other Enexpensive upgrade in reply to 39 M puller, 08-23-2002 14:47:29
Call lemmons at # 765-938-1808 in rushville indiana
Flyin Farmall
08-24-2002 03:13:43
 Re: Re: M More Power,RPM's,or other Enexpensive upgrade in reply to jim, 08-23-2002 19:10:28
If you want rpm's-tighten the governor spring...pressed steel,you should do itif you have it!!put your weight where you need it.there is alot of a lot cheap HP if you look hard enough!!
